How to export html table to PDF and then excel?
I want to export html table to PDF and then to excel.
Can i export directly?
If so, I want to know how to export html table to PDF and then to excel?
Hi jen,
It is possible to export html table to PDF or excel.
Firs you have to write a program in asp.net,PHP or jsp that can do the work for you.
There is not any stable solution to directly export without writing any custom program.
Please try to go to the programming forums and there are a lot of solutions about exporting html tables in different formats.
Thank You.
There are many ways to do the same thing you can just copy the HTML table put it to a word file and then convert it in PDF form or either you can copy it to directly in excel by putting all elements and its a copy paste work.
It also depends upon the table size and data used in tables so you need to think about it.
Smith Thompson
