How to export a Microsoft Access forum to Google earth?
I need to export discussion of Microsoft Access to Google earth. Does anyone can help me to export this to Google earth. I need it with little urgency.
Thanks
Thanks
Dear Patty,
Have you ever heard of KML(Keyhole Markup Language). Basically the KML format is used for display geographic data in an Earth browser. If you want to export the discussion of MS Access to Google earth then you have to export it to a KML file first. Then you can manually start Google earth and import the KML file.
How to import KML file : First save your doc with a .kml extention.
Open Google earth
Click file
Click open
Select the KML file and open.
