How to export PDF to crystal report?
I am not familiar about crystal reports, would you mind explaining some important detail about crystal report as well as its purpose and how does it work?
I really have to make sure on this issue so that I can be able to answer all my case study report for next week’s submission.
I need your help.
Waiting for your support.
Hi, Chloe!
You can do it the following way: Insert > OLE Object
Select Adobe Acrobat document and select the PDF file you want to show.
Crystal Reports (CR) it is a report generator for Windows. Its file format – .rpt. CR it is an application for extracting data from different sources and represent them as report. CR allows to do simple and complicated reports. In the Database Expert you can select and link tables from different data sources.
There are many Experts in CR for creating reports in interactive mode. The user can group, classify, formatting objects, move objects between reports.
Also the user can move objects between report and applications which work as OLE server (for example MS Word or MS Excel)
Regards!
