How to export rtf tags excel?
Hello Experts,
How to export rtf tags excel? Well I am always using excel in doing my reports and other important activities that needs to be encoded and named in column and row. I just want to know if there are some way that I can export rtf tags in Microsoft excel. I hope you can give me some advice regarding this issue. Thank you.
Best Answer by Kaile Smith
Answered By 0 points N/A #179925
You can export files in two ways.
  1. Go to the ‘save as’ option select .csv format and save it. Now use MS Word for opening the saved file and save it in RTF format. It can process some limited data, not large amount of data.
  2. Only using excel the RTF format file can be exported.
https://www.techwalla.com/articles/how-to-convert-xls-to-rtf
Answered By 0 points N/A #179926
Hi Isabella,
You can export rtf tags to excel by using a converter, saving a code, or having a backup files. You should have a right converter to proceed in exporting or write the right code. I will share with you the URL where you can download a converter.
http://tags.topshareware.com/rtf-format-to-excel/downloads/1.htm . Here you can download a compatible converter in exporting.
Try also this link.
to have a code that can also help your problem.
Thank You.
