How to export swf file to flv in Mac OS
Hello experts,
Please give me some tips and instruction how to export or convert .swf file to .flv in Mac operating system. Because I need it for my project a .flv file is required and what is the software being used?. I need help on this.
Best Answer by Luke N Marks
Answered By 5 points N/A #154234
Dear Kevin,
Since you are a mac user I would highly recommend using the software "Handbrake" for this conversion. swf to flv
It is a software that serves users to convert across numerous platform. And certainly your requirement will be fullfiled
Just follow this link and click on the Mac OS Download option
https://handbrake.fr/downloads.php
It will download the software onto your computer for installation.
Regards
Answered By 85 points N/A #154235
Hello.
There is an application for MAC that will enable you to convert SWF to FLV format.
It is called Doremi soft and can be downloaded from here.
To use the app
  • Click on the add video button.
  • Browse for your SWF file.
  • Change the output to FLV
  • Click the next button
  • The file will convert
Another option is to use an online video conversion website such as you convert it.
It can convert the SWF file to over 17 formats including FLV format.
The site id free to use.
