How to Export to XML in Tiled Editor for Mac
I have Tiled Editor for Mac. It was really a great software for the game that I'm developing. However, I only got one problem. How do I export to XML in Tiled Editor for Mac?
Hi Justin,
This is a very tricky question, but it is as simple as it sounds.
Here are the steps that you need to follow.
1. First create the map that you desire and that you need to export.
2. Next you need to save the map and while you are doing this please make sure you are saving the map in the TMX format, because the TMX is same as XML.
3. Now from the file menu on the top, select the export option and then select the file name and at the drop down box which ask you to select the format or the extension, please select TMX, which is same as XML. And then click on OK.
4. Now the map has been exported to XML format and you can use the same based on your needs.
Also make sure you go to the menu option and then preferences and select the CSV or Plain instead of Compression. Only do this if the file is not exporting to TMX the first time.
Bell KEny
Notifications
