How to extract and explore winrar file explorer?
Hello experts,
How to extract and explore WinRAR file explorer? There are some files that are needed to zip and compress so that it will be safe from viruses and other malicious software that can possibly harm the date. Now I am having an error such as unable to extract files can you help me resolve this issue?
Answered By 0 points N/A #183479
Hello Christine,
Hope you are searching for better answer for extraction of rar file.
This error may be happen for some reason. If you have uses demon version of winrar this troubleshooting can be happen and for this reason you need to download original file.
Or you may have bad download,  you have a bad uploader, because of malicious invasion. For that reason during downloading the whole file is not downloaded successfully Use extracts now software for extracting all kind of archived
Extraction process:
General process for file extraction click right button on the expected file, select extract file, then show the place of output and then click OK.
You didn’t tell us about the operating system that you are using. For .rar file explorer for Linux
Best of luck.
