shovon_7
Posted on - 12/01/2012
Hello IT Experts,
I have a unreal tournament 1999 cd image & i want to save the data within it in my pc. But, i cannot find any system utility that let me to open this kind of file. Is there any kind of software which can be used to open the cd image & extract data from it? Thanks in advance.
How to extract data from unreal tournament 1999 cd image?
Hi shovon_7,
There are several ways on how to extract an image file. An image file usually has an extension name of iso right? If you have a WinRar application installed in your system, you can use it to extract the image file into a folder. All you have to do is to open the location of the iso file then select. Right click the selected iso file then select ‘extract files…’ then select the destination where you want to extract the file then click ‘OK’.
