I have a corrupted avi file that still has sound but the picture moves frame by frame slowly or sometimes it freezes. Would downloading a CODEC solve this or are the frames damaged and irreparable? Can I still extract images corrupted avi video? I'm on Windows xp 64 bit sp2. Thanks.
How to extract images from corrupted avi video
Hello Maycle
 I understand your problem. Unfortunately you cannot extract the images but  still there is a way to recover the images .
First download hjspilt software and  convert  the  avi  file to flv using options.
Now play the file using vlc  player and press shift+w key together in the image which you want to extract. All images will come out as JPG.
Hello, Maycle Clark!
You are facing a problem with your avi video file because it has been corrupted. Don't worry, this is a very easy way to extract images or videos from a corrupted file. You just need to use a software to do this. The software name is AVI MPEG WMV Workshop. This is a very powerful software. This software is very user-friendly and easy to use. Hope you will be able to do this easily. Your problem will be solved.
Have a good day.
