How to extract rar clock face for themes?
Hello friends,
How to extract rar clock face for themes? My friend zipped and sends a .rar file composed of clock face themes but I don’t have any idea on the extracting process. A step by step process or instruction will probably solve this issue.
Thanks and Regards,
YOUNG HERNANDEZ.
Best Answer by Carrie Westmoreland
Answered By 0 points N/A #165910
A rar file is a compressed file that can be opened using various softwares such as winrar or winzip . Here is the link to download winrar https://www.rarlab.com/download.htm
1. Download the file and then install it ( Double click on setup.exe)
2. Download the attachment that you've received from your friend.
3. Right click on the attachment and click on extract here.
That should get you the files that you're looking for. Thanks!
Answered By 0 points N/A #165911
Mr YOUNG HERNANDEZ
You can use WINRAR for extracting your zipped file . I am giving you the solution step by step below
1. Go to File hippo or this link https://filehippo.com/search?q=winrar
2. When you open the link you will find a download option for winrar 4.20 ,
3. Here you will find downloads for 64 bit & 32 bits
4. Download it from your operating system
5. Install it .
6. After finishing the installation right click on your zip file
7. You will find an option EXTRACT FILE
8. Click on it
10. Press OK
Task complete.
Enjoy.
Thanks
Carrie Westmoreland
