How to extract symbols from the following image
I want to extract these symbols from the picture below.
I want to use them to make fonts or something other.
Can anyone please tell me which software except PhotoShop should I use to do that.
The image is attached for your guidance.
Best Answer by Johny Smith
Answered By 0 points N/A #128649
Hi Ranaasad,
The only way of extracting the symbols from this picture or from any picture file is through the use of a picture editing tool such as Photoshop. Of course if you wanted to use another program instead of PhotoShop there are a number of different software's that you can turn to.
If you did not wish to spend anything or wait for downloading to finish of a copy of a free software, what you can use is the built in Paint tool that is in every Windows OS. It not only is free but it is easy to learn and for simple picture editing Paint is not a bad choice. There are other free software's such as Gimp or PhotoScape.
Hope this helped you out.
Answered By 0 points N/A #128650
The procedure to guide you finish your work is as follows:
Open the image.
Right click on it and click copy.
Go start menu all program accessories paint.
When you click paint a window titled untitled –paint will appear. On the tools bar
  • Click file and then new or simply press Ctrl + N.
  • Click edit and then paste or simply press Ctrl + V
  • If there is no tools pane on the left of the window click view tab and select Tools box or simply press Ctrl + T.
  • Place the mouse pointer over the tools in the pane to learn more. E.g. Click the select button to cut a shape in the picture.
Very easy to use
