A Najam
15 points
Posted on - 09/26/2016
when your mobile screen gets frozen, app crash, keypad touch problems arise, cannot hear from the phone, phone makes noise, cannot make or receive calls etc. then the solution is to factory reset your device. How to factory reset a LG phone?
R Carlos
10 points
How To Factory Reset A LG Phone To Solve The Problems.
Factory reset should be done only when it is necessary. It removes all the settings and apps including contacts, media, email accounts etc.
HOW TO FACTORY RESET LG G2
1) Switch off your device.
2) Press the power button along with the volume down button till the logo appears.
3) When the LG logo appears, release the power button and again press it immediately.
4) Release the buttons when factory data reset screen appears.
5) Click yes.
6) Volume buttons are used to scroll up and down whereas the power button is used to select.
7) Click yes for the reset.
For the other versions of LG, follow the same steps for factory reset.
