How To Find Adobe Acrobat Serial Number To Install The Application?
I have purchased Adobe Acrobat software and when I am try to install it on the PC it asks for a keyword. Where can I find Adobe Acrobat serial number for the installation process?
The product key location depends on the method of you purchase. There are three possible ways.
1. A prepaid card: It is a card that is given with the purchase of CD and a card is also provided. Behind that card, you may find a serial number.
2. A product box: If at all you don’t find a card. You should look for serial number on box of the CD or inside the box. Sometimes it may also be on the CD cover.
3. Email: If you have purchased from a reseller instead of authorized Adobe store you may have to provide an email id. You will receive the serial key from the reseller in the email id you have specified.
