How to find best frameworks for web applications ?
Hi Experts,
I am looking for best frameworks for web applications.
I would like to get these from internet.Any expert post me the link to find the best.
These frameworks should be merely for web applications.
Halleleilani2
Best Answer by Toni Linscomb
Answered By 10 points N/A #141598
Hello Halleleilani2,
Here is the website which having the download link of framework for web application.
Follow the procedure to download it.
Hope so you will get the drivers from here.
Take care.
Regard,
Harthy Opera
Answered By 5 points N/A #141599
I can recommend you some IDEs with my personal and industry experience
If you are using .NET frame work the best IDE is Visual studio 2010.
There is a latest version of 2012 release but I haven’t used it yet.
For PHP programming Adobe Dream Viewer and the wamp server are the best technologies to use.
For java programming Netbeans is the best IDE I’ve found. Netbeans 7.2.1 is the latest version and I have use 6.7 version which I can recommend you
For database programming SQL Server is the best and my experience is with Sql Server 2008.
Since SQL Server is a commercial product you can try the express edition with some limited functionality
