When you want to login on the router’s login page, but have forgotten the IP address, finding the local IP address saves us. It is useful even when we want to assign a static IP to the computer. how to find Cisco router IP address?
J Kresl
How To Find Cisco Router IP Address To Assign Static IP Address.
TO FIND THE LOCAL IP ADDRESS OF CISCO ROUTER:
1) Connect the computer and router through any of the Ethernet ports.
• Open start menu.
• Open Run.
• In the open field, enter cmd.
• In the MS-DOS prompt, write ipconfig/all.
• Search for default gateway as it shows the local IP address. WINDOWS 98
• Open start menu.
• Search for run dialog box.
• Type winIPcfg and enter.
Default gateway shows your local IP address.
