How to find dell studio webcam drivers?
Recently I have changed my operating system and now I have windows 7. My previous os was windows xp. Now my webcam is not working and asking for drivers. Please tell me how to find and install dell studio webcam drivers?
Best Answer by Vinson forman
Answered By 5 points N/A #156557
My analysis is that your previous driver is not compatible with your current operating system. To be sure and safe download drivers from Dell's official website only. Dell has support page for requesting driver or browse thru categories. I cannot tell you exactly what to download because you did not mention your computer model. Instead i will give you a link that will help you locate your webcam driver.
www.dell.com/support/drivers/us/en/04/ProductSelector/Select?rquery=na
Select your product type and computer model from the category.
Hope this will help.
Answered By 0 points N/A #156558
Dear Sharlene,
Thanks that you have shared your problem with us.
It is very simple to install your camera driver into your computer.
Kindly connect you camera with your computer via cable, it will start a process of installing driver. Open device manager and check if a yellow question mark is showing on your device in device manager then connect to internet and go to https://www.driveridentifier.com/.
There will be a little software called "driver identifier" download it and install it.
It will scan all your system for drivers and then it will redirect you to the driver download page.
Download your desired driver and install it. And enjoy.
Happy computing.
