Dav1d
Posted on - 07/16/2011
I want to find some information about Manufacturer, Model type, Serial number, Headset brand, Handset model, Frequencies.etc.. for example: I’m using Nokia NXX and my IMEI is 35267704721184X. and someone said that we can ask Mobile Service Provider to block my phone registering with another Mobile Service Provider, when it’s stolen. Is that correct?Â
Best regards.
How to find information about Mobile based on IMEI
You can find almost information that you want by accessing link input IMEI to get information as below :Â
(Sample Information)
Type Allocation Holder
O2
Mobile Equipment Type
O2 XDA Mini
GSM Implementation Phase
2/2+
Information on range assignment
Est. Date of Range Issuance
Around Q3 2005
Reporting Body
British Approvals Board of Telecommunications (BABT)
Primary Market
Europe
Legal Basis for Allocation
EU R&TTE Directive
Information on number format
Full IMEI Presentation
357308-00-014080-2
Reporting Body Identifier
35
Type Allocation Code
35730800
Serial Number
014080
Check Digit
2
In order to know IMEI number, you can dial *#06#, in most cases it will show the IMEI number, otherwise turn off your mobile and remove the battery.Then you will see the IMEI on the compliance plate.
The IMEI number can prevent the others can use your mobile by stopping the phone register with other mobile service providers.
Thanks
Hello dear friend,
Just go to wiki for details about your phone IMEI.
mberm008
International Mobile Equipment Identity or IMEI is a unique identification number for mobile phones, usually for GSM, WCDMA and/or some satellite phones. IMEI can be found at the back of the GSM handset or by dialing *#06# and is usually 15 digits long.
There are Samsung mobiles that has a feature called 'mobile tracker' which is helpful for lost handsets. When mobile owners choose to activate this service, they will be ask to enter their preferred recipients for an SMS that contains their name and the IMEI of the phone.
Once a new sim card has been placed on the phone, it will automatically send a text to the chosen recipients and it may contain the number of the new sim card that was inserted.
The original owner can request to block the phone from their network providers and the phone will become useless. You may also contact your network provider for additional information.
