How to find out best free property xml tree editor?
Hi to everyone. As xml is markup language used for transport and store data. I am using xml files in my project and I need some best free property xml tree editor to open xml files and edit it easily. Any editor which can provide information while coding in xml and make it easier to understand it. Please some guidance is required.
Best Answer by Alexander Dubson
Answered By 30 points N/A #142421
Microsoft visual web developer is good for you to edit.
It's free and the software will tell the error by underlining in red.
After that you only to hover that word and find reason and fix it.
You can download it here.
I hope this answered your problem. Have a nice day.
Answered By 0 points N/A #199387
There are plenty of options you can choose from; however, you mention that you’re interested in an editor which helps with the scripting part of the process.
XML Editor is one of the best options as it gives you all that you need in terms of xml editing in a straightforward interface and with warning signs on which parts of the scripting may be in need of help.
