How to find percent as2?
How to find percent as2? I cannot seem to find the percent of rendering a file in my flash as2 application software. Is there a way that we can pause a file while rendering? I hope that you can show me a feature in as2 that seems to be more useful whenever we save a file. Thank you guys.
Waiting for your support.
Best Answer by Shifflett Laurel
Answered By 0 points N/A #165953
Dear YOUNG HERNANDEZ,
You asked for the as2 flash percentage application software. There is a lot of flash percentage software out there, and I suggest actionscript2, which will be more reliable for work. It is very easy to use. To work with it, just go here: http://the-dude.co.uk/tutorials/flash-as2-tutorials/advanced-flash-preloaders-as2/
Answered By 0 points N/A #165954
Hellow Young Hernandez,
I have got the point . You may know that actionscript allows a lot of ways to format your text runtime.There is a TextFormat class can be used for setting character and paragraph formatting for TextField objects. I am giving you most standard property in the Action Script 2.
It is _xscale Property.It evaluates the horizontal dcale of the text field as applied from the registration point of the text field,expressed as a percentage.
If you can understand the property you will be able implement this .
Regards
Shifflett Laurel
