Hello fellows,
How to find the program upload speed limit? Sometimes we have to monitor the upload and download speed limit of our internet connection. In our office, there are some instances that we upload files the whole day. I just want to know the process of monitoring the computer’s internet connection upload speed.
Thank you.
David Bailey.
What program are you using for uploading your files? Different programs or softwares have specific settings with regards to upload speed limits. Most of them however are put in Unlimited upload speed. Since you are uploading files in your office, I can assume that a large number of people are using your internet connection. If that is the case, the speed of your internet connection slows down which in turn slows down your upload speed. You can check your internet speed connection as well as its download and upload speed at www.speedtest.net
I see your post and you want to see the speed of the upload of your computer maybe you can visit this site https://testmy.net/ so you can monitor the upload given by your computer and record the speed test of your computer. It can help you to see the accuracy of your computer while uploading. Thank you! Other site is: http://www.speedtest.net/
