How to find a remote IP (Internet Protocol)?
Asked By 7060 points N/A Posted on -
Hi All,
Thank you.
Best Answer by James20
Answered By 5 points N/A #79448
Hi dear,
This is the answer.
To view someone's IP# when they send you a Hotmail email do this:
  • Click "Options" on the upper right side of the page;
  • On the left side of the page, Click "Mail";
  • Click "Mail Display Settings";
  • Under "Message Headers" select "Full" or "Advanced";
  • Click ok.
Answered By 590495 points N/A #79449
  • Computer has its own IP address and a unique identifier called Mac address. This separate your computer amongst others, can be known as finger print of a computer.
  • Websites uses DNS – Domain Name Server instead of IP address to remember their website easily instead of long list of numbers.
To check remote IP address, here's how:
  1. Go to Start, Run and type cmd and press enter key.
  2. This open Command Prompt window.
  3. In the blinking cursor, type ping and the website you want to know the remote IP address.
  4. Example is ping https://www.google.com/?gws_rd=ssl and press enter.
  5. This gives you reply and an IP address.
This is the remote IP address that you are asking for.
