roger neil
20 points
Posted on - 08/26/2012
Hi Experts,
I am having a small network at the office. I have to find a single word domain. I configured DNS server but could not achieve this. Any networking expert may help me. I have installed Windows Server 2007 on my desktop. There are 10 computers as clients. Thanks.
Roger Neil
How to find single word domain?
There are a number of ways from which you can search and find a single word domain name.
https://www.leandomainsearch.com/Â Â is very good for showing which single word domain names are available.
https://domize.com/Â Â a very helpful domain center, using its advance search options you can point it towards a text list file of single words, check for availability.
https://instantdomainsearch.com/Â Â a valuable domain search engine, you can search single word domains also.
http://www.nameboy.com/Â Â It allows you to select on the basis of primary words.
https://domaingroovy.com/Â Â Join for free and search number of single word domains.
You can get various ideas for your searching on a single word domain names using this site and also check for domain availability.
Hope that helps!!
