How to find unuse files on Mac?
Hello Experts,
How to find un use files on mac? I need to know what is the best way to find unused file on mac operating system all the functions and short cut keys that needs to be learned, for after searching all unused files and other application I will going to remove it to make my space more bigger.
Thank you.
Best Answer by Goram Ian
Answered By 0 points N/A #174751
Hi Jessica,
You can find your unused files and applications on your mac operating system by using a software known as CleanGenius. This software shows you all the files and applications that are not currently used and also give you suggestions on how to manage and increase disk space. Here is the link of the software.
link:-   https://www.easeus.com/system-utilities/mac.htm
This software comes with 15-day trial version.
Hope it helps.
Answered By 60 points N/A #174753
Hi Jessica Allen,
I have read your problem and I think it is the best way to discuss it with other Mac OS Users. I have attached the link of good forums that tackles about your problems.
Hope it would help you a lot with your problem. thanks and more powers.
