Toby Malone
40 points
Posted on - 05/15/2012
Hi guys,
I got an Active Directory error message when I am trying to run the Password Policy Manager. The error message looks like this:
Any help would be very much appreciated. Thanks.
Error:
Current security context is not associated with an Active Directory domain or forest.
How to fix an Active Directory problem when running Password Policy manager?
The error message is showing because the authentication has no domain control. To exterminate authentication delay change the message level security and use a username “clientCredentialType”:
And set a value “Ntlm” into the “clientCredentialType”, and set the security mode as “Transport”. The code has to be exactly like this:
<security mode="Transport">
<transport clientCredentialType="Ntlm"/>
</security>
The “NTLM” function handles the “credentials” of a “security principal”. The “Initial Security context” and “Accept Security Context” must be performed by the “credential” handler.
Note: whenever the process request does not have access to the” Credentials”, the function will return an error message.
Let me know if its work………enjoy.
