How to fix ActiveSync errors in my Window Mobile 7?
Hi! I have a server with Microsoft Exchange Server 2003 installed. It had some hardware issues so I am trying to move the mailboxes to a different server, but when I move them, the action causes ActiveSync errors on the Windows Mobile 7. Have anyone had this problem before or does anyone know how to deal with it?
Answered By 20 points N/A #104947
Hallo Princessaira,
You may be getting the active sync errors when you try to move mailboxes to your windows mobile 7 because there is an intermediate certificate authority that is not available on the device, or maybe on the server which you are using for the syncing process which is running the exchange server.
To resolve this issue, you will need to use a group policy configuration so that you can be able to distribute the certificates to all trusted members in the domain that you are on. I will advise you to visit the link below to get more details on how you will add trusted users to the group policy.
http://technet.microsoft.com/en-us/library/cc738131(WS.10).aspx
Hope this helps.
__
Regards
Mahesh Babu
