How to fix AppleSyncNotifier.exe error
I am a user of iTunes but I have been faced by a series of errors including the one shown below. Whenever I restart my computer I get that error shown below. Please provide me a way of solving it.
Error: The procedure entry point xmlTextReaderConstName could not be located in the dynamic link libxml2.dll.
Answered By 0 points N/A #184062
Hi Mohammad
The cause of this is the Apple Sync Notifier.exe it is trying to load information from a database but can't find the right DLL file.
For Fixing this follow this simple steps
For 32 bit-Go to Local disk C then choose program files then common files then Apple then Apple application support
For 64 bit-Look for program Files (x86)
Then copy the two DLL file namely the libxml2.dll and SQlite3.dll and paste it to Mobile Device Support.
Local disk C or C/Program files (base on what type of it your using)common files/Apple then Mobile device support.
