How to Fix Blue Screen Memory Dump Issue?
Hi experts,
I am getting an error on my pc  desktop that is memory dump error.Can any one help me.
Thanks
andrew rusta.
Best Answer by warren todd
Answered By 0 points N/A #168919
Hey andrew,
The issue can be caused by two possible problems i.e the hardware and software of your PC.
1.Please check hardware incompatibility on your system.
2. If you have just inserted new hardware or have recently upgraded the hardware on your system, you need to take it out or revert back to your old setup immediately.
3. The first thing to do in this case is to look at when the error shows – if it appears when you are using a specific program, then you should try re installing that program.
4. If you are getting the physical memory dump error randomly then it could be caused by "registry". To fix this problem, you should try using a 'registry cleaner'.It can fix all the damaged and corrupted settings that can cause this error.
5.Please check this by replacing the OS.
6. Kindly check this by replacing the memory also.
Answered By 0 points N/A #168920
Hi Dear,
It is RAM generated error. Console your ram.
Answered By 10 points N/A #168921
Hello Rusta,
I think your desktop is showing a blue screen during memory dumping. It usually called blue screen of death. You can overcome this problem only by cleaning the memory. It happens because of irregular entries into memory. You can try cleaning the registry but it does not work all the times. So we usually just reinstall the windows.
Whoever faces this problem should take steps early. Because sometimes it causes a serious damage in RAM. My suggestion is make the backup of your important files and folders than reinstall the windows and stay safe.
Thank you,
 Riley Weaver.
Answered By 0 points N/A #168922
Hi
The problem can be caused by two possible problems i.e the hardware and software of your PC. Go this page to get more information according to this issue.
