How to fix BlueFlare Antivirus scam
Hi experts,
In the past few days, we’re in receipt of grievances regarding a software package known as BlueFlare Antivirus.
According to all we have researched with reference to this application, it is a fraudulent anti-virus software.
It exhibits deceptive safety warnings as well as untrue scan outcomes in a determination to persuade operators to fork out money for the full version of the application.
It might construct network browsers to use a proxy server, while it hinders system utilities, corresponding with the system records collected from our users.
Can you guys help me how to deal with this problem?
Thank you very much.
Best Answer by Nixoncruzy
Answered By 0 points N/A #110611
If you install it, the threat will store csrss.exe file on your Startup folder and it will open automatically when you start your Windows. And then, it will start the virus with a filename %AppData%BlueFlare AntivirusBlueFlare Antivirus.exe.
Remember that the csrss.exe file that automatically installed on the Startup folder will never be confused on the legit Microsoft C:WindowsSystem32csrss.exe file.
In order to uninstall this antivirus, you need to download and install any task killer software or you can also use the System Service by pressing the Ctrl+Alt+Del. After this, you need to switch the tab processes and then search for the BlueFlare Antivirus Manager.
When you find it, close the entire tasks and then download a malware remover software.
You can use the Malwarebytes. Download it from the link and then install it on your computer.
Run it and then restart your computer.
Answered By 0 points N/A #110612
Just enter the activation code and install completely
Registration code: DB038748-B4659586-4A1071AF-32E768CD-36005B1B-F4520642-3000BF2A-04FC910B
Then clean with rkill removal tool
