Hello Experts,
How to fix broken aac file? There are some files with a format of aac and I need to fix it as soon as possible for there is an error occurred when I attempted to open it. It says unable to open file. I am thinking that maybe the file was corrupted.
I hope you can give me some way to resolve this issue.
Thank you.
Hello Janet! Good Day,
There are a lot of software all over the web that lets you fix not just a corrupt or broken aac file but most of the music files. One software you can use is BeSliced 0.2. It can fix corrupted audio files. It is also a freeware software.
Feel free to visit this site for more information and for downloads:
http://www.softpedia.com/get/Multimedia/Audio/Other-AUDIO-Tools/BeSliced.shtml
Hope this helps!
Hello Janet,
AAC is a type of audio files we use. These files can sometimes get corrupted as have happened in your case. There are several software you can use those can fix corrupted AAC files. Here is a software that can fix corrupted audio files along with AAC files.
http://www.digital-digest.com/dvd/downloads/showsoftware_besplit_224.html
Use this and your problem will be solved.
