How to fix camera application on iPhone 3g?
hello, I have a problem with my iPhone 3G , it started to perform a bit slow and the camera does not open its shutter every time i try to run the default camera application? a little help please?
This is in fact a hardware issue. So if you are having this issue,
you may want to contact Apple, especially if the fixes below do not work for you.
Or you may try the following fixes:
> Turn your device off and on again by pressing and holding the Sleep/Wake button for a few seconds.
> Try resetting all settings on your iPod Touch: Settings > General > Reset.
Note that this will reset all of your preferences and settings but this will not affect all your data and media.
Thanking you
Franke Mary
