How To Fix Canon Printer Error With Different Error Codes.
Asked By 35 points N/A Posted on -
Canon printer is one of the recommended printers to print any sort of document. It has high quality. But even this has some issues which are related to error codes. Each error code can be solved by different methods depending upon the problem. how to fix canon printer error by removing the error codes?
Answered By 10 points N/A #83045
The Error codes of canon printer are as follows:
1) Error B200 PROBLEM: abnormal print head voltage.
SOLUTION:
–>Change the print head and logic board.
–>Change the power supply unit.
2) Error 5100
PROBLEM: error in the carriage encoder signal.
SOLUTION:
->scratches can be present on the carriage slit, so you nee d to clean it.
–>Any outside material would have entered the carriage environment, so you need to remove that material.
–>You need to reset the ink absorber.
3) Error 5200
PROBLEM: print head is overheated.
SOLTUION: switch off the printer and let it cool down. After sometime switch it on again.
4) Error 5400
PROBLEM: The internal temperature does not match the ideal one.
SOLUTION: Either replacethe print head, carriage unit or the logic board.
5) Error 5700
PROBLEM: a fault has arisen in the gears of the printer.
SOLUTION: replace the sheet feader.
6) Error 6000
PROBLEM: error in the LF encoder signal due to paper jam with pins, paper etc.
SOLUTION: -> clean the LF slit film.
7) Error 6A00
PROBLEM: jamming of cartridge mechanism.
SOLUTION:
8) Error 6A90
PROBLEM: error in the APP motor.
SOLUTION: remove the foreign material.
9) Error 6C10
PROBLEM: faulty valve can sensor.
1) Error B200
SOLUTION:
2) Error 5100
SOLUTION:
3) Error 5200
4) Error 5400
5) Error 5700 PROBLEM: a fault has arisen in the gears of the printer.
6) Error 6000
7) Error 6A00
SOLUTION:
8) Error 6A90
9) Error 6C10
