How to fix certificate error
This is my problem for almost 3 day. Everytime I log on to twitter, certificate is always error and the date and time of my computer is correct. How can I fix this ? Thanks is advance.
Hey Alden clayton!
If you are getting certificate error then there are three possible problems that becomes the cause of certificate error.
1. Time and date is not updated.
2. Expired Security Certificate
3. Un-trustable website.
As you have mentioned above that your time and date is correct then this must be cause by the expired certificate or un- trustable website.
I will recommend you to check your date and time properly, if, after checking date and time you are still facing the error then the security certificate is expired, as it should be renewed time to time.
Thanks
Tunacao Caaron
You can fix your computer certificate error on your internet explorer by using some software application that you can download for free or with payment.
But first you need to know why and what is a certificate error, certificate error as the name suggest is the application on which your browser detects that a particular website you visited containing errors, meaning it is hiding or the webserver is hiding its identity in order to commit some fraud like stealing personal information from you, once you use this site and give them personal details about yourself then you will become vulnerable from malware,spyware and even viruses.
The common symptoms of having certificate error on your system are high cpu usage, program locks up,slow pc performance,systems freezes,the computer will suddenly shut down without any reason, and installation errors when your trying to install new software for your computer.
The solution is very simple and hassle free you just need to download PC Cleaner its a software program that you can run,once installed to your system to do a registry clean up and repair tool for your computer system.
These kinds of has to be smacking various fill balancers every single obtaining various installation on the certificates along with their own respected stores which an example may be busted. Your bill may very well be older.
You are able to repair this challenge by launching the best second time beginners carts to the afflicted machines. Tweets possesses improved the certificates intended for myspace. com. SSL can be an encrypted standard protocol utilized to defend swap data. Damaged SSL stores can lead to a person.
Notifications
