A K Azad
35 points
Posted on - 09/30/2016
The full form for SSL is secure sockets layer. It is a product of Netscape. It creates an encrypted connection between the server and visitor. This is done so that your private information is not leaked, and it is received only by the expected receiver. How to fix certificate error?
E.Robe
10 points
How To Fix Certificate Error To Establish The Encrypted Connection.
CAUSES:
1) The website you are using is not trustable.
2) The certificate has expired.
3) The date of PC has expired.
HOW TO FIX CERTIFICATE ERROR?
i. Correct your computer’s time and date.
ii. Open Internet Explorer.
iii. Go to Tools menu and select Internet options.
iv. From the window appearing click on advanced tab.
v. Go to security tab and uncheck – ‘check for publishers revocation’ and ‘check for server certificate revocation’.
vi. Click on ‘apply’ and then OK.
vii. Again open the web browser.
The error should be solved.
