I have this chess game in my Samsung Galaxy SIII. However, when I play chess, I got this weird problem in my sound. When I play chess with sound for Android, the sound just randomly freezes, especially when I received SMS. How could I fix this?Â
How to Fix Chess with Sound for Android?
Hello Calistamadisonn,
There are many chess games available in the Android Market and there will always be some pros and cons on every game.
As you know that, the games which we play and download are not in-built games so there will be a compatibility issue sometime. Even when I play some games and if my phone rings then or get an SMS then the game will freeze so the only option I am left is restart the game which is frustrating at times.
There is no 100% solution for this, but you can try putting your SMS tone on Silent mode (not even in vibrate mode) and see if it works fine.
If there are lots of applications and games installed in your Android phone then it may give you this type of problem. What I would suggest to you is that just keep the games which you really like and remove all the unwanted items from your phone as it will give better performance while playing.
Keaton Christopher
