How to fix the cinnamon taskbar icons size ?
I'm running a LMDE Cinnamon on my Acer computer. I'm having a problem with the icons in the system tray. I want to reset their size. How to fix the cinnamon taskbar icon size? Please suggest a detailed method.
Answered By 0 points N/A #158558
I found a faster way to amend the system tray icons on the Acer. It involves one modification. Open /usr/share/cinnamon/applets/[email protected]/applet.js and find this on line 8; const ICON_SCALE_FACTOR = .88;
I wished my tray icons to be sixteen pixels and the height is twenty five pixels thus I modified this size too .64. You'll be able to confirm your desired size by dividing desired font size / panel height. The panel height of your theme is overridden in cinnamon settings.
Skype icon to get connection status
Now your icons like update manager, Skype, truecrypt, Xchat etc., can show during a similar size to the remainder of the icons.
