Jody Akerly
80 points
Posted on - 09/18/2012
I received a configure fantastic Fla error in my Windows 7.
I have tried to copy the Configure Fantastic Fla file from another operating system and replacing it on my machine.
Nevertheless, it didn’t help.
I have started to think if there is virus in the registry.
What is going on and how to fix it?
How to fix configure fantastic Fla error
Hi Jody,
Configure Fantastic Fla is a Windows 32 bit application that may lead your system malfunction, if your PC is infected with Configure Fantastic Fla or missing the necessary components of Configure Fantastic Fla.
I recommend installing Configure Fantastic Fla Windows Errors Fix Tool for FREE.
Follow the link to install Speedy PC Fix Error.
Thank you,
Mae Cabanero
A configure Fantastic Fla is located in the system32 folder by default. It is usually spyware that create errors with the Fantastic Fla. Errors occur because the spyware changes the default location and replace it with a fake file with a similar name.
Another reason why you might have the Fantastic Fla error is because you might have an incorrect or incomplete un-installation.
Your computer will therefore operate very slowly; Blue Screen of Death will occur occasionally, system crash and pop up messages will show constantly.
To fix the error automatically download:
To fix the error manually:
1. Update your windows system
2. Uninstall the latest software that might have created this error
3. Reboot your computer.
If the error persists:
1. Click on the start button and type in regedit
2. Open the HKEY_LOCAL_MACHINE folder
3. Click on the Software folder, Microsoft folder, Windows folder, Current Version Folder.
4. Click on the Run folder and then Configure Fantastic Fla File
5. Cut the file to the Desktop (just in case)
6. Update your PC
