How to fix corrupted files in XP?
Sometimes when you executing some program an error come saying that your file is corrupted and cannot it run your program. There can be various reasons for the files being corrupted.
To fix this issue do as follows:
You will require these to fix it:-
Now it will load and fix your entire corrupted file on win XP.
It’s done .
To fix corrupted files in Windows XP, run the Chkdsk command using the Command Prompt utility. The command scans all the files on the operating system, locates the corrupted ones and repairs them. How to go about it:
Hello Dear,
Thanks that you have shared your problem with us. Dear it is so easy to repair corrupted files using windows XP.
Windows XP provides a best check disk utility to repair all types of files.
You should check the files location first then go to dos and write this command in that location.
I mean if you have corrupted files in C drive then,
C:/> chkdsk press enter
It will scan your computer for corrupted files and sectors and clusters and will repair them.
Thanks
