mysaf
Posted on - 09/11/2011
Hi guys , I am using a Edirol Audio Interface to record MIDI data.
But when I tried to do MIDI sequencing in Adobe Audition I got stuck up with notes.
I don’t know how to stop them.
Any one of encountered this? Please help.
UA-101(1)
Error 4 – Failed to open device
How to fix Edirol UA-101 error ?
Try to turn off the keyboard for a while and then turn it on again. Otherwise, since it will be impossible to do the sequencing with this step, try to knock on the advanced switch at the back of your Edirol device and disable the ASIO driver. If you are still getting errors on this, you can read on the manual of your Edirol device. Just click on the link below:
Download UA-101 Owner's Manual
