How to fix error when connecting Nokia PC Suite to 7610?
While attempting to connect my PC Suite by using a USB stick to my 7610, I keep on getting the error message “Connection to Nokia PC Suite failed. Please reinstall Nokia PC Suite. (Code: Init IMediaControl2)”.
In trying to fix this error I have installed the drivers (DKU-2 USB) and PC Suite (6.2), uninstalled everything and used the Nokia Registry Cleaner. Restarted the PC after every installation, reconnected the phone and managed the connection in the Control Panel.
My computer uses the Windows XP Pro operating system and is fully updated. Even after completing all of the above steps, I still receive the same error message. Can someone help me?
