graceiyaz
Posted on - 09/13/2011
Hello guys,
I need your help there is an error every time I logged -in to my Special Force account.
I have been searching for solutions for this, but I could not find one.
I badly need your help to get me out of this problem for how many days now.
Thanks in advance.
Special Force
FALSE7: recv socket error
How to fix False 7: recv socket error?
This is a common result of a registry problem in your system. You can do these steps to get rid of the error: download an error repair tool like Perfect Optimizer, then let it scan the computer for you by using the Scan All button. Wait as it scans your computer for eroors. After that just click the Repair All button. It will restore missing files or prompt you to download corrupted files. After that, you can go on with the game. You can also uninstall all the components of Special Force including MYGAME Launcher. Just go to the Control Panel and in the Add/Remove Program, choose Remove/Uninstall. Make sure that all the components have been removed as it may cause further error during reinstallation. Restart the PC and install it again with MYGAME launcher. Do the manual patch which will take several minutes so you have to wait then restart the PC. See if it all works.
