How to fix a fatal error to run QuickBooks arabic books?
I installed Quickbooks Pro 2005 to run Quickbooks arabic books on my windows 7 . That time , I got a flash error and encountered fatal error when I was trying to run Quickbooks arabic books . After re-installing, the problem remains the same . How can I fix this problem .
Answered By 30 points N/A #159193
Hi there Hanley Samson,
You're getting the flash error, and not the application error, so the flash is the one you should address your problem too. Instead of reinstalling the software, try reinstalling your flash, using the newest version.
Another thing to try is to is to turn the compatibility mode on for the software. Right click on the application icon, choose Properties and under the Compatibility tab check the option 'Run this program in compatibility mode' and select 'Previous version of Windows'.
Confirm the changes by clicking OK button.
Best regards,
Drake Vivian
