iwanttoknow
Posted on - 03/11/2013
I have a problem opening games in my Samsung champ. Every time i want to run a game, i have an error message . How can this be fix?Is there a free downloadable software that can fix this problem?Where can I find it?
How to fix game error message in samsung champ
Most commonly this error occurs for Java problems. When it gives a message then you should read it carefully and find which version of Java it is asking for. There are many versions and add- ons of Java if your mobile phone is old then it will require old version of Java. If it requires any version then go to Java site and download that and I hope it will help you to solve this problem.
Best of luck.
