How to fix generic firmware upgrade LG Smartphone?
I recently purchased LG smartphone and upgraded firmware to latest version yesterday, since then my smartphone is not functioning well. Whenever I try to call, I can’t do so. Anyone tell me how to fix generic firmware upgrade LG smartphone? Any kind of help would be appreciated.
Best Answer by Sara Jokny
Answered By 0 points N/A #134217
This should be easy to fix, since there is a LG support site which contains all the data and updates you need to make your Smartphone work. Check out this page, http://www.lg.com/ca_en/mobile
Make sure you select the Smartphone model and stuff like that. Hope this helps.
regards,
Answered By 0 points N/A #134218
This type of problem is typically happens when you are using a program that is incompatible in your bit system. Make sure that you follow all the instructions for the firmware update and make sure that you have a backup copy of the data that you are updating. Once the drive was recognized ran the firmware update tool and followed the prompts and rebooted.
Wish this will help you.
