What is the best way to fix Generic Host Process for Win32 Services?
What is Generic Host? Â I have found error Win32 Services has encountered and needs to close. What is the best way to fix the problem?
Charles Wilson
Ronald01
5 points
How to fix Generic Host Process for Win32 Services?
To solve the problem you have to install the hotfix which actually supports Microsoft and Windows XP service pack two. and the error of Generic Host Process can produce at any time in your system and there is no proper reason for this. you might get the error after a short interval of time when you get logged in. the main reason might be the previous logged in process that how did you shut down your PC or it suddenly shut down due to some problem. if you have "Hotfix" it will automatically install new update at every connectivity with internet and repair such kind of problem on its own automatically. Some times you install the hotfix and you still get an error. you actually wants to restart your system to activate the hotfix.
Hotfix also performs some additional tasks for the safety of your system. you can learn a lot more about this from internet if  you are good in searching. try to download a good hotfix from a trustful source.
Hello Dear,
Thanks for sharing your problem with us. Dear it is advised to scan your computer with antivirus. It is due to virus. I suggest you a software Antivirus to scan your system. You should use Panda Antivirus 2013 pro.
It will give you the best results in this regard.
You can download it from here.
https://www.pandasecurity.com/usa/homeusers/solutions/antivirus/
I hope it will work better.
Thanks
