How to fix Hcl ec2 technology low buffer popup
Hi Experts,
I am using Hcl ec2 technology and very happy till now. My only problem is pop saying low buffer dynamic. Someone told me this is because HCL utility HCL EC2 software, Please let me know what the exact problem is and how to fix it. Thanks
Answered By 30 points N/A #168018
Hello Floyd,
The problem you mention it’s a common problem while using HCL EC2. Sometimes it happens due to one of the HCL utility. It’s a simple one to solve. At first just go to the task bar there you will see the HCL EC2 tray. Now right click on it then select Take snapshot from that menu. It will take less than one minute. After that, simply reboot the system. I hope this will resolve your problem.
Good luck.
