How to fix icc management Windows 7 display problem
How to fix ICC management Windows 7 display problem? From Vista version, it disabled the active ICC management profile. When upgraded to Windows 7, was it reactivated?
When you are upgrade your OS sometimes it may reactivate or maybe some other issue. This is how you should fix it. Please follow the below instructions.
1. Click on "Start" and then type "Color Management". Open the utility by clicking on it.
2. Select "display 1" on the "device" menu.
3. Click and check box "Use my settings for this device".
4. Set your profile as default by clicking on "set as default profile" button. When this is done it should display as "default" in front of your display in the profiles.
5. Now click on "Profiles" and then choose "Combine my settings with system defaults" option.
6. Click on "Advanced" and then "change system defaults".
7. In color management "system defaults" open tab "Advanced".
8. Then check the box "Use Windows display calibration" and "close" and exit color management utility.
Hi there,
Yes, this feature will be activated when you upgrade your Vista to Windows 7.
And now to fix your problem with the ICC management-
* Go to your Color Management Software.
* Create an ICC profile.
* Then paste is to C:Windowssystem32SpoolDrivers.
After that go to your desktop, right click then go to personalize.
* Click Display.
* Click Change display settings.
* Go to Advance settings.
* Select Color Management.
* Click Add button.
* Then add your ICC profile.
* And finally, click it as default theme.
This is a feature of all NTFS type OS of Microsoft like XP Vista and Windows 7.
Hope this thing works for you.
