How to Fix Intel Fortran message error?
Hello. I am looking for solutions to this error that I got:
Check environment variable NLSPATH and protection of pathname/for_msg.cat.
The Intel Fortran message catalog file was not found. This error has no condition symbol.”
If you have a solution to this please post it here.
Answered By 5 points N/A #152360
Hi Bryan, your problem can be solved, what you need to do is look for the catalog file in the web.
This you will do by; Going to fredist.txt copying the redistributable files and pasting them to the location usr/lib/ifcore_msg.cat
Run the registry editor by going to Start > Run > regedit to open the registry window.
In the registry window go to the following folder; HKEY_LOCAL_MACHINESOFTWAREFortran
Delete all the files under the folders in that section
Restart the software and the problem should be solved.
Thanks
