jasper lee
Posted on - 11/28/2011
I accidentally hit my iPhone on the floor. I broke the digitizer then I tried to fix it with glue. I put all the broken pieces together, but I noticed that the top right portion of my iPhone is not working. What should I do with it? The touch screen feature is working except on the upper right portion of the screen. Please help me. Thank you.
lee hung
75 points
How to fix iPhone 3G S broken digitizer
Hello Jasper Lee,
It seems that the screen was affected and therefore will not be able to work well. I will advise that you just get a new screen for your iphone for you to be able to experience all its functionalities.
But in case you think that it can still be repaired then look for a place near you when phone repair is done and see if that can be able to repair the iphone screen and nay other part of the phone that may be affected.
I would have recommended that you contact the vendor who sold you the iphone and see if they can replace for you with the warranty if you still have it but I doubt they will accept that because that was your mistake, and not an error due to the system itself.
__
Regards
Lee Hung
