Hi Guys,
My ITunes is tracking a match error frequently. What does it mean? I searched several sites to get a remedy of this issue but no result. Have you any idea for the match error?
Please help me to get a remedy of this issue on my MacBook?
How to fix iTunes Match Error in Mac?
Good day,
Regarding to your problem, my advice for that is scan your ITunes with any antivirus software as long as it is reliable one. And if you find a threat, virus or any infected parts then remove it. If it does not work uninstall the program and install it again.
Hope this on can help you.
Hi Jeffrey,
It is possible that there is just a server load with ITunes loading the songs. You can try to click on the Options > Procedure this will leave the contents on your Match library untouched and intact. If all else fails, you can convert the track where you are getting most the issue to AIFF Encoder found on the Import Using drop down menu. If it is more than 2 tracks you can convert multiple files from the same applet.
