How to fix jpeg headers free?
Hello experts,
How to fix jpeg headers free? Is there a built in software for windows xp operating system that can auto fix a photo with jpg file header? I need to fix those files immediately or any software you can recommend that will really help me about fixing jpeg headers? Thank you.
Best Answer by Trotsky Timothy
Answered By 5 points N/A #186156
Hi Ericson Eric,
If you want free jpeg headers for your Windows XP operating system, you can go to the websites below:
Good luck.
Answered By 0 points N/A #186157
Hello Ericson,
Once the Jpeg header is corrupted, you cannot view the originally saved file. To fix the jpeg header you have to download a software called IrfanView, it's free and easy to install. After installation re-save your Jpeg header so you can restore it to it's original functionality.
Answered By 10 points N/A #186159
It is actually not a very easy task because you will not get the actual header. You can use Hex editor and by using that you can convert the corrupted file into a jpeg file. HeX editor is not enough for you because in the HEX editor there is also some problem. Camera is a factor in this problem. If you captured all your photos using one camera then you can use just one photo.
So try this process and i think that will help you.
